Farmall Tractors Discussion Board
SUPER H FARMALL HELP
Posted by JACK VAUGHN on June 23, 1999 at 15:36:47 from (205.188.192.31):
HELP! Super H will not start. I have fire to plugs and gas to carb. and 110lbs. compression on each cylinder. It was running real low on power when it quit. I put knew points and plugs in.Tried pulling off with truck and it backfired a few times. I think it may be the timing, but have moved distributor around
Post a Followup
: Re: SUPER H FARMALL HELP
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
