Posted by Matt in WA on March 09, 2009 at 13:56:02 from (65.54.155.45):
Have a 1950 Farmall M that runs good, except last 6 mo. temp. gauge keeps getting up. I blew out the radiator with the compressor, and flushed the radiator with the garden hose. Not much rust and fluid looked still pretty good, after approx. 2 tablespoons of rust. Belt to water pump is good, and no water leaking at water pump. I always greased the zirks on the pump also. My question is, should I go ahead and pull the water pump and take a look at it? I believe the gauges have always been accurate. Have the service manual somewhere here, need to find it. Thanks for any advice.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
