Farmall Tractors Discussion Board
Farmall 450 gear whine in reverse and other Questions
Posted by MarkS on July 01, 1999 at 12:19:43 from (206.146.188.160):
I recently purchased a Farmall 450. Tractor runs and shifts easily. I get a loud whine from the power train when the tractor is in reverse, loaded or unloaded. Is this normal and if not how might I determine where the problem is in the drive train?
Also, I've used the tractor a bit for grading in reverse (with a box blade) and it seems to have an automatic brake when in reverse and on a slope; i.e. it doesn't try to roll even with the implement off the ground. Normal? or am I driving it with a parking brake on? (parking brake lock on foot pedals is not engaged.)
there is a mechanism below the left side of the seat with a lever which is raised or lowered. Mechanism is connected to the 3 point. what is the function of the lever and associated mechanism?
Thanks.
PS: for those of you that helped when I couldn't get it running last month, THANKS! It turned out sometime previously the distributor had been rebuilt and installed 180 out. I got it figured out and it runs better than ever with all the new ignition components.
Post a Followup
: Re: Farmall 450 gear whine in reverse and other Questions
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
