Farmall Tractors Discussion Board
Farmall H gas problem
Posted by Ryan on July 17, 1999 at 16:23:07 from (205.188.196.39):
We recently restored my 1952 Farmall H and we had to take the gas tank off. When it was all put back together and started we noticed it was flooding. My grandfather cleaned the carb and said we could have stirred up dirt down in the tank. We took it to a show and when I was driving around the track it was sputtering like before. Once it sat a couple of minutes you could start it and drive for a liitle bit then it would do it again. So we put a in line filter on the line and cleaned the carb again. When I was driving around the house to make sure it was working right it seemed to run really good. Once it ran for about a half an hour it acted like dirt was in it. I waited a minute and it started on the first time. Then a little later it did it a couple more times. When you let it sit for a couple of minutes it starts right up. I think that the filter we put in the line is not letting enough gas get through and when you let it sit a minute enough gas seeps through to let it run for a little while. Can someone help PLEASE!!!!
THANKS,
Ryan
Post a Followup
: Re: Farmall H gas problem
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
