10-20 throttle linkage-Bob Kerr
Posted by Will@ont.ca on March 08, 2002 at 14:22:11 from (216.58.67.35):
I can't seem to get it.When all the linkages are hooked up the butterfly in the carb ends up to be open.From the front of the tractor the spring loaded lever in the govenor moves from left to right ,which causes the knuckle affair on the other side of the rad to go counter clockwise which causes the carb butterfly to also go counter clockwise,which shuts the carb off when it should be opening it up [IF the butterfly should be closed when engine is off].I just can't seem to grasp the problem.The tong that sticks out of the throtle shaft is in the slot at the carb. Will
Post A Followup
: Re: 10-20 throttle linkage-Bob Kerr
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
