1946 farmall cub
Posted by Arvil Porter on March 08, 2002 at 21:53:15 from (216.76.248.65):
The tractor stars up fine and Idles , but when you increase the throttle it will run for a few secs. then quit , If you add about 3/4 choke it will run better, If you run the screew all the way in it seems to run a little bit better to try and fix the problum I did a valve job have 75 lbs compression on all clyd,s rings must be worn a little,
the timing is corect, installed new points and condencer, rotor rotor cap, cleaned the fuel tank and lines, got good fuel flow to the carb rebuilt the carb , Diden know the flot setting so I left it the same it has a soled needle and seat no sings of whair on eather no sticking eather , no holes in the foat New head gasket new manafold gasket, new coil, recheked the timing , after all this no chang ? used soape to try and see if I had a air leek couldent find eney the tractor Idles good jut wont run long if you give it the throttle
Gov seems to be working ok'also, Iam open for just about eney sugestions to get it runing right,
Arvil
Post A Followup
: Re: 1946 farmall cub
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
