1066 Reverse problem pin-pointed!
Posted by Mitch Sisson on March 12, 2002 at 14:06:02 from (64.89.160.30):
I took the side cover off, when I shift to reverse, the reverse drive gear is pushed foward - out of the way - unless the teeth are lined up just right. What is supposed to hold the gear in place on the shaft? Is there a way to fix this without tearing down the entire backend? P.S.: The Tractor Vet knows his stuff! I used his tip about parking the tractor on a slope before removing the side cover - Might have lost a cup of transmission oil! Thanks guys - keep up the good work!
Post A Followup
: Re: 1066 Reverse problem pin-pointed!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
