Re: Char-Lynn SMTA leak
Posted by Bob M on April 03, 2002 at 06:57:20 from (165.170.128.66):
In Reply to: Char-Lynn SMTA leak posted by Dick Davis on April 03, 2002 at 04:22:12:
Dick - Before you start messing with the PS unit itself, check hydraulic manifold on the side of the PS unit. The Charlynn was leaking pretty bad when I got my SM. Turned out the two allen head screws that clamp the manifold to the PS unit were slightly loose. A half turn on each screw stopped the leak.
Could also be the O-ring seals under the manifold need to be replaced.
Post A Followup
: Re: Re: Char-Lynn SMTA leak
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
