Re: steering box bolts?
Posted by big fred on April 03, 2002 at 07:11:22 from (12.13.226.13):
In Reply to: steering box bolts? posted by Randy on April 03, 2002 at 05:01:55:
Randy, on my 300U a previous owner/mechanic had replaced the 3/8 bolts with 7/16 studs. I suspect he had a similar problem, as he put 7/16 helicoils in a couple of the holes, and it looks like the casting around the holes had been damaged. There is plenty of room for the 7/16 helicoils and studs, but you will also need to drill out the holes in the clutch cover to accomodate them, as they are a pretty snug fit for a 3/8 inch. You will probably also need to drill out the holes in the steering box. Also check to make sure your steering gearbox stabilizer, which mounts to the front of the gearbox, is in place and intact. It takes up a lot of the reaction loads on the gearbox.
Post A Followup
: Re: Re: steering box bolts?
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
