140 Steering help
Posted by HavinFuninMo on April 13, 2002 at 15:45:27 from (64.196.152.44):
Well, I finally broke down and ripped into the front end to find out where the 3/4 turn of slop in my steering wheel is coming from. It is coming from inside the gear box as when I hold the "flat" worm gear from moving, the steering gear arm still moves about an inch.
I am trying to remove the steering gear arm and having a bear of a time trying to get it off. Nut came off pretty easy but that arm is stuck to the shaft bad. I have soaked it with PB Blaster and fabed a 1/4" thick plate that I slid above the arm and attached my puller to. The plate is now all bent up from pulling so hard on it. I do not have torches to heat the arm up so it will expand. Anyone have any ideas?????? Help!!!
Post A Followup
: Re: 140 Steering help
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
