350 PTO Adjustment?
Posted by Mr. N on May 08, 2002 at 18:58:57 from (216.180.201.99):
On a 350 Farmall (Gas), is there a way to make adjustments the PTO lever? The lever will not move all the way back into the slot for the "on" position. Also, my shop manual says the PTO takes two quarts of fluid--how do you drain/fill?
thank you.
Post A Followup
: Re: 350 PTO Adjustment?
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
