what's the socket size for spark plug on 560?
Posted by dvtw on May 17, 2002 at 11:18:14 from (136.205.16.3):
I don't have a deep well socket that will fit my "new" 560 Farmall spark plugs and noticed it is leaking or at least has some compression leaking out around the #3 plug. It doesn't smoke or miss but you can see it leaking air/fuel out around the spark plug. I've never seen this before or know why it would do this unless it was just loose. Do these plugs have seals? The plug seems to be tight as best I can tell and like I said, it doesn't miss at all.
Also, does anyone know how to replace the seals that would cause the rear brakes to leak. The left seal leaks very bad. The breaks aren't very good as a result I guess of all the oil in the disc/drum. Need to get it fixed.
Thanks!
Post A Followup
: Re: what's the socket size for spark plug on 560?
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
