Re: Stuck exhaust valve on Farmall 200
Posted by Shawn on May 27, 2002 at 17:38:13 from (64.12.104.166):
In Reply to: Stuck exhaust valve on Farmall 200 posted by 560man on May 27, 2002 at 14:06:04:
I am new to these parts of internet Farmall tech. I once worked on these beasts in school about 14yrs ago, now work on my semis, all diesel stuff, but a valve problem should be same gas or diesel w/ diesels eating them harder at a 14+ compression ratio. Your problem seems to change occasionally with the popping coming & leaving for a bit. A stuck valve is stuck!! A bent stem might move sometimes but not likely, because once the bent part sticks in the guide its their. A valve seat seems more likely to move around. If this were the case you need to pull the head. I know this aint fun but better than a valve busted & smashed into the piston dome. In my opinion the gasket set is cheap compared to a piston & liner, check the head out & be sure.
Post A Followup
: Re: Re: Stuck exhaust valve on Farmall 200
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
