Re: farmall M will not start
Posted by Jim in Michigan on June 06, 2002 at 17:58:51 from (12.34.47.12):
In Reply to: farmall M will not start posted by mark h from pa on June 06, 2002 at 13:40:43:
I had the same problem with my H. It had sat for years and when I pulled the plugs out there was spark, but the tractor wouldnt run, I put a lil fuel in the spark plug hole and still nothin,,, It turned out the plugs were bad, I had a old mechanic tell that he had seen plugs that would fire out of the engine but in the engine they wouldnt. so I changed the plug and he was right... she fired right up.....I dont understand why this happened but it did,,, just a thought...Jim
Post A Followup
: Re: Re: farmall M will not start
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
