300U mystery valve
Posted by Matt on June 07, 2002 at 20:16:51 from (12.82.71.21):
My 300 utility has 4 spool valves bolted to the resevoir/manifold,two stacks of two valves. Three are the "Hydra-Touch" spool valves ( 2 for the loader, 1 for the 2-point )The forth mystery valve is different and it is spewing hydraulic fluid. This valve is in the rearmost set sandwiched to the resevoir,has no actuator 2 spring loaded spools. It is ported out the back 1 port to the power steering 1 to a loop that hits the 2 outside valves (supply?) Is this perhaps a pressure regulating valve for the power steering?
I replaced the "o"rings but it keeps blowing the snap ring of the vertical spool out and hydro fluid to the ceiling of my shed.
Hope someone has some tips, I'm new at this but getting frustrated
Post A Followup
: Re: 300U mystery valve
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
