IH 300 Utility Transmission
Posted by Mic on July 16, 2002 at 10:03:22 from (128.146.54.229):
I have found an IH 300 utility. TA is out, at least it makes a high pitch whine/whistle when engaged. The transmission, however is very difficult to shift. The gears will not stop rotating when the clutch is depressed to let you get it in gear. Once it is in gear, the clutch appears to function fine. Any suggestions on what might be going on? Also, previous owner filled transmission case with automotive transmission fluid, which has been drained back out, however the front transmission joints are seeping oil now. Think that this may have something to do with it? Thanks.
Post A Followup
: Re: IH 300 Utility Transmission
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
