Re: Stuck F-20
Posted by Bill Smith on August 25, 2002 at 10:46:26 from (128.242.4.59):
In Reply to: Stuck F-20 posted by Tony on August 24, 2002 at 22:44:17:
If stored outside, make sure you get that exhaust covered or fixed first. Then take plugs out. Keep fluid in the cylinders (I use automatic transmission fluid). People use alot of various liquids but I would stay away from anything that is highly evaparatable. Jack up one rear wheel and maybe block it if you don't want to tie your jack up for along time. Over the coarse of 3 to 4 weeks, keep fluid in the cylinders and put transmission in gear and rock that jacked up wheel back and forth. You may also use the cranke but I wouldn't get to rowdy with that ( no need to mess up the cranke or the shaft it goes on). If this fails to loosen it up, you might as well take the head and pan off. Then you can work directly with the piston, or pistons that are stuck. good luck to you
Post A Followup
: Re: Re: Stuck F-20
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
