Re: Changing the mag condenser on my H
Posted by Mike Schotte on September 02, 2002 at 15:10:16 from (209.246.131.51):
In Reply to: Changing the mag condenser on my H posted by Ted Goss on September 02, 2002 at 14:36:47:
Hi Ted,
To remove the condenser on the H4 you need to do the following:
1) Remove kill switch wire, and unscrew the brass grounding post from insulated washer.
2) Remove coil cover. You will be able to see the top of the condenser, laying sideways below the front of the coil. There is a vertical screw with a hold down clip that retains the backside of the condenser and grounds it to the mag body. Remove this.
3) Remove the two screws on the backside of the mag and remove the oval access plate. Behind the plate is a round hole that the condenser slips out of. It goes without saying that the magneto will have to be removed from the tractor for you to access this side of the mag.
Re-assemble in reverse order. Good luck!
-Schotte
Post A Followup
: Re: Re: Changing the mag condenser on my H
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
