Farmall 130 12 volt conversion
Posted by Jeremy on September 29, 2002 at 17:27:44 from (152.163.189.203):
Two years ago I was on this web site and used a diagram from a Farmall M to convert my 130 over to 12 volts and it worked. Since then the wiring has been tampered with and I forget how I did it. Thanks!
Post A Followup
: Re: Farmall 130 12 volt conversion
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
