My tale of woe and the happy ending
Posted by WIRED on December 04, 2002 at 15:00:19 from (156.46.176.74):
My hands have finally thawed-out enough to type again, and I just had to share this story. Last Monday night, we got about 4" of snow in southern Wisconsin. I was thrilled. This was to be my first opportunity to use my 1949 Cub with the front blade to plow snow. I was shoving snow all over the place, having a great time. That little 6V tractor started right up in 14 degree weather, and moved some big drifts without any extra weight or tire chains. I thought about putting the chains on, but it appeared they might chew up the fenders, and I didn't want to remove the wheels in order to do that. When plowing in 2nd and 3rd gear, I had no problems keeping traction. After I finished about 3/4 of the job, I shoved a big pile of snow into place, and went to put the tractor in reverse. I let the clutch out, and the tractor went forward. I took it out of gear, put it back in reverse, but again the tractor went forward. So I tried 1st gear, and the tractor went forward -- and it felt like 3rd gear. 2nd gear -- same thing. 3rd gear worked like 3rd gear. Reverse again - and sure enough, the tractor wanted to go forward in 3rd gear. So I put it in neutral, let the clutch out, and again I went forward. I was stuck in gear. I drove it in front of the garage and fiddled with the gear shift lever, trying to get reverse, 1st and 2nd back. No luck. So I shut her down. It was 8:00 at night, 14 degrees, and I decided to start a transmission repair project. I pulled the shift lever housing cover and discovered a thick, white gooey mass where I expected to see gears. Obviously, there was water in the transmission housing, and after working the tractor hard for a while, the ice and water froze the gears up. I pulled the drain plug and watched the stuff ooze out -- it was the consistency of caramel! Then I ran inside to check the operators manual and determine what weight oil and how much of it I was likely to need. 3 1/2 pints of SAE 80. So off to WalMart I went in search of a gallon of SAE 80. Home 20 minutes later, I sprayed paint thinner in the housing to clean out the ooze. 1/2 a gallon rinse was what it took to get everything bright and shiny once again. Next, I had to figure out how the gears meshed, and after studying the manual for 15 minutes more, determined that a screwdriver and a few foul words would fix it. I dumped the oil in and reassembled it. My hands were frozen! I restarted the tractor and let the clutch out -- NO MOVEMENT! Then I tried reverse -- IT WORKED! Then 1st -- it worked. But now I had no 2nd or 3rd gear. So off came the housing cover again, and 10 more minutes of fiddling around. I reassembled things once again. Reverse and first worked, now 2nd and 3rd worked too! SUCCESS! I decided to finish plowing, then put the little guy away. Got back in the house at 11:00 p.m. colder than the proverbial witches private part. I determined that the housing gasket was the source of my problem, so a new one is on its way. This time, I'm going to bring it in the garage with the propane heater going before I start the repair. I'll probably change the oil again to ensure all the water is out. This antique farming thing sure is fun!
Home
| Forums
Today's Featured Article -
Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
