IH Model 240 engine speed
Posted by J oe on March 09, 2003 at 16:18:59 from (152.163.189.203):
I just completed a top end rebuild on an early 1960's IH Model 240. It started up fine and idles smoothly after I adjusted the valves and carb. The problem is that it won't rev up to the high rpm's. This problem was there before I worked on it and I noticed that the previous owner had installed a "helper spring" on the linkage to the carb. The governor adjustment screw is almost all the way out and the governor appears to work at low rpm but it just won't rev high. I can manually pull the linkage to the carb (overide the governor) to get it there.
Also, the throttle lever on the dash has a strong spring under it and always pulls it to the HI mark, is this normal? If anyone has any ideas, I would certainely appreciate it.
Thanks
Joe
Post A Followup
: Re: IH Model 240 engine speed
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
