Starting an M for the first time after overhaul? Need help!
Posted by Farmall Daddy on March 16, 2003 at 17:55:13 from (209.183.116.152):
Got the starter to turn the motor over. Tried to pull start it today, and it started, ran for a couple of minutes, then croaked out when my dad tried to pull it out of a driveway in low gear. Pull started it again, ran same amount of time, then died. After it died the second time, it overheated, had a small leak on one hose, but fixed that. My dad adjusted the timing on it. Tried it again, nothing. Adjusted it again, ran for 30 seconds, then died. I adjusted it, ran for about 1 minute then choked out. What steps should I do to get her running long enough so I can set the valves? What does the book recommend the valves be set at. I have set the valves at 12 thousandths when cold, and then when it was heated up, but not running on both times. Any help on a list of steps will be greatly appreciated
Thanks!!
Post A Followup
: Re: Starting an M for the first time after overhaul? Need help!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
