Farmall Tractors Discussion Board
Re: replacing rear main oil seal
Posted by p on September 13, 1999 at 15:53:15 from (209.186.155.9):
In Reply to: replacing rear main oil seal posted by Oli Svenson on September 12, 1999 at 19:01:02:
This is a tricky question. I just did a complete overhaul on a cub and my rear main seal caused me all kinds of trouble. The original style seal is a steel one that presses into the retainer. this aluminum retainer is supposed to be replaced with a new one to use the new style seals. The new seals is a rubber unit that fit kind of weird into mine. This seal is supposed to fit tight but just slipped in on mine. It appears like the flywheel will hold the seal in place when installed but don't be fooled like me, it doesn't. The Case IH dealer told me the retainer was about $150 and available in a few days(A.A. Anderson in Harvard, IL look on Case IH website for phone number). I installed my seal and worked fine for a couple of mows and began to leak. I have been told by the dealer mechanic silicone will not work to seal. I tried "lock-tite gasket eliminator" I guess i did not work. Finally I discovered my opil level was too high (forgot to drain the oil filter on oil change) and the seal has not leaked since. BUT I don't know if the problem is still there and it is only a matter of time for a replacement. SO! be careful. If the seal fits loose, you need a new reatiner to save the headache. If it fits tight GO FOR IT! please let me know how it works!! and I hope this helps.
Post a Followup
: Re: Re: replacing rear main oil seal
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
