Farmall 300 won't stay running Help
Posted by Mike on April 26, 2003 at 17:03:32 from (204.42.16.125):
I have a Farmall 300 that will run a few minutes then quit. Let it sit a few minutes it will start right up then repeat the cycle. I have changed the coil, plugs, wires, condenser, points, cleaned the carburator, new sediment bowl screen and base. It quits just like you turned off the key. What have I missed. Please help thank you.
Post A Followup
: Re: Farmall 300 won't stay running Help
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
