Hey, Charles -- Re: Electrall thread below
Posted by Wardner on May 05, 2003 at 11:23:08 from (63.159.177.110):
There is not much you can do with the Electrall unless you have a gear box. The MTA through 660 uses a constant mesh mid-mount gear box that drives off the IPTO gear behind the main tractor clutch pressure plate. Smaller tractors used a step up gear box bolted to the Electrall. These were all driven by rear PTO. Some were two point mounted and some were trailer mounted. At the left of this page click on "Tractor Photos" and "Implement Photos" and type in "Electrall". There will be a few pictures. I have an original manual that I can scan and email to you. You should also do a search on the Farmall Forum for many posts relating to Electrall. If you are near Eastern Massachusetts, you are welcome to look at my original F400 set-up.
Post A Followup
: Re: Hey, Charles -- Re: Electrall thread below
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
