Re: High altitude pistons- hard to get used to the knocking
Posted by Steve - IN on May 05, 2003 at 21:33:28 from (12.222.17.59):
In Reply to: High altitude pistons- hard to get used to the knocking posted by Jonesy on May 05, 2003 at 20:25:12:
Jonesy,
You might try some octane booster in the gas, or pick up some gas at a local airport. Airplanes fly at high altitude as well, and have gas to match - a situation very similar to your pistons.
Over time, the higher compression ratio of your pistons will cause the piston tops and the valve bottoms to have little dimples blown out of them, just the same way a piece of metal that has been left sitting outside will look like it has acne. I've seen the results in a few engines: it's not pretty. The other trick to try is to retard your timing a bit, but that's not as certain a cure as a higher octane gas.
Best wishes in helping the M to live a longer and even happier life.
Post A Followup
: Re: Re: High altitude pistons- hard to get used to the knocking
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
