Re: Engine problem when loaded
Posted by hal on May 06, 2003 at 05:38:53 from (63.122.73.81):
In Reply to: Engine problem when loaded posted by John Julian on May 05, 2003 at 22:17:08:
it sound like you have a fuel restiction. we had one time on a IH 400, a spider(s) got in the gas tank and finally ended up in the port that the gas travels through into the sedimate bulb. take the bulb off, and check the screen and open the valve all the way up. the gas should spray out in two streams that almost will be horizontal, if it doesn't something has it pluged. if it does, then take the line off at the carb and see what stream you have there. it should run at a full stream as well. then if you still have troubles it most likly is in the the needle and seat and/or carb. you can all so take an air hose and blow back to the tank through the line at the carb and see if that doen't help. we found that the spiders like to build there nest in the nozzel in our gas barrel. what an easy way to get in there!
Home
| Forums
Today's Featured Article -
Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
