Leaking oil from steering gear box
Posted by Knothead on May 11, 2003 at 07:41:55 from (216.76.214.135):
My 1950 cub was feeling a little stiff when steering, so I stupidly added 30 weight oil to the gear box the other day without doing a search on this site for gearbox oil. I now know that I should have used 90 weight gear oil. This morning, there is a small puddle of oil under the "Happy Tractor" at the gear box. Have I damaged the lower seal? Should I remove the drain plug and drain all oil and then replace with 90 weight gear oil? What about the stiffness in steering? The steering wheel needs to be pulled back to center instead of coming back by itself after making a sharp turn. Any help or ideas would be appreciated.
Post A Followup
: Re: Leaking oil from steering gear box
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
