H clutch bearings
Posted by Dan G on May 27, 2003 at 10:50:06 from (24.231.130.9):
I have the lift all pump dropped out of my H because I had to replace the transmission seals. I understand that I can get the clutch out of the bottom and replace the throw-out bearing but can I also get to the pilot bearing thru the lift all opening? One of the two clutch bearings is making noise (not sure which) when I push in the clutch. I'm assuming that it is the pilot bearing because when I did finally find the grease zerk for it, and gave it a shot of grease, the noise did quiet down a bit. It still makes a little noise though, and I thought now might be the time to replace it.
Post A Followup
: Re: H clutch bearings
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
