Re: Choking M
Posted by Paul in Mich on July 27, 2003 at 07:28:50 from (66.188.4.217):
In Reply to: Choking M posted by Jeff on July 26, 2003 at 08:23:47:
Ther could be a couple reasons for dying out at idle speed. The obvious of course is that your idle is set too low and can be adjusted with the idle adjustment screw on the carb next to the governor shaft. The next possibility is a little more subtle. Check and see if low idle causes some vibration which in turn causes your chock to work itself out thereby killing the engine. You can check that easily by pushing your choke in all the way and if that corrects the problem, then you either have to replace the little ball bearing behind the choke lever on the carb, or hook up a spring to keep the choke from working itself out. The other possibility is that the float in your carb isnt closing properly and letting the fuel level get too high in the carb, thus flooding out at idle speed. this is very common, as you use up the fuel at higher rpms, but dont at idle. If you have dripping fuel underneath the carb, that will signal that your carb is loading up, and you will need to adjust your float. Since it runs OK otherwise, I would start with those 3 scenerios before making any adjustments anywhere else. If you do have to rebuild the carb, the kits are around $25.00, and pretty easy to work on yourself. Good Luck.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
