Re: Gasket material for hydraulics
Posted by TimV on August 19, 2003 at 06:07:39 from (12.39.239.130):
In Reply to: Gasket material for hydraulics posted by David Bean on August 18, 2003 at 09:25:55:
David: Even without knowing the specifics of the application, I'd steer clear of cork. Cork is mainly used for low-pressure applications, and probably will not hold up under even the modest pressures of an older hydraulic system. The "grey paper" is more than likely a lower-grade gasket sheet with a nitrile rubber binder. This should hold up (from a chemical compatibility standpoint) to hydraulic fluid, but may also give problems under elevated pressures due to low tensile strength. However, it's probably the better choice of the two you mentioned. Be wary of using sealant on a hydraulic system--if you put too much on, it can extrude into the sealed cavity, break loose, and clog your system.
Post A Followup
: Re: Re: Gasket material for hydraulics
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
