Re: Re: Re: Re: Two way hydraulic
Posted by steve on August 21, 2003 at 19:03:06 from (204.246.222.83):
In Reply to: Re: Re: Re: Two way hydraulic posted by Farm w/Junk on August 21, 2003 at 17:49:22:
you should be able to blow thru the ports and figure it out. routinely the "IN" and "OUT" will be on opposite sides of the valve. in the neutral center position, blow thru the ports and air sould go straight thru on one pair. ---the cylinder ports are normally just a couple inches apart and probably on the same side of the valve. pull the valve spool forward to the "raise" position. now blow thru the ports and the inlet will go to the "raise" and the outlet would be connected to the "lower" or drain side. next push the spool in to the "lower" position. now the two cylinder ports will be switched and the inlet will be connected to the "lower" port and the outlet will be connected to the other end of the cylinder which is now the drain. you can also look at a couple valves at the local farm store to get an idea. many valves have the ports numbered or lettered if you look close. it helps to number the ports, then make a drawing of which are connected when you are in neutral, raise, and lower positions.
Home
| Forums
Today's Featured Article -
A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
