Re: Re: Re: Second generator still no charge-HELP!
Posted by Bob M on August 29, 2003 at 06:54:13 from (165.170.128.66):
In Reply to: Re: Re: Second generator still no charge-HELP! posted by Bob Quale on August 28, 2003 at 16:31:39:
Bob - That troubleshooting guide is for a regulator-equipped system. If your "regulator" has no FLD terminal, it's actually a cutout. Troubleshooting a cutout is a bit different... here's what I'd suggest: With the motor stopped, connect a jumper wire from the generator F terminal to a GOOD ground - the grounded battery post is best. Now run the motor at ½ throttle or faster, and with an assistant watching the ammeter connect another jumper between the BAT and GEN terminals at the cutout. If the generator is good, the ammeter will show a decent level of charge (+10 amps or so). It also means the cutout is either bad or is not properly grounded as Haas suggests. However if you get nothing or a discharge indication when you make the connection, the generator is bad. If the generator tests OK, then the problem has gotta be in the charging system F circuit. If you have an ohmmeter you can test it like this: Remove the wire from the generator F terminal. Connect one ohmmeter lead to the disconnected F wire and the other to a GOOD ground. With the headlight switch in the L (low charge) position, the ohmmeter should read around 2 or 3 ohms . In the other three positions (H, D and B) the meter should read close to 0 ohms. If the readings are higher (or infinity) either the switch is bad or the switch is not grounded, again as Hass suggests. If it turns out the problem is the light switch and you don't want to mess with it, you can simply permanently ground the generator F terminal. This set the generator to "high" charge full time. Unless you the tractor for hours on end, it will work fine this way. Just check the battery water level occasionally and refill if it gets low. Hope this helps!
Home
| Forums
Today's Featured Article -
Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
