Re: Re: Re: IH 350 Utility
Posted by parts man on September 07, 2003 at 20:44:18 from (142.166.242.72):
In Reply to: Re: Re: IH 350 Utility posted by Allen on September 07, 2003 at 05:04:34:
Allen, if you block the passages at the pump it will build up pressure and have no place for it to go. This will either strip timing gears or split the pump. If you run a line from one port to the other add a reservoir so when the oil heats up there will be room for expansion.
If you don't plan to use the system under the seat just leave it hooked up and running through the original way and take the handle off the valve on the side.
Post A Followup
: Re: Re: Re: Re: IH 350 Utility
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
