Re: Re: Re: Farmall won't start
Posted by Big Jim on September 09, 2003 at 13:40:15 from (199.141.125.33):
In Reply to: Re: Re: Farmall won't start posted by Jeff Daugherty on September 09, 2003 at 12:23:11:
The fellow talking about a "ring gear" is referring to the gear around the flywheel. If you take your starter off the tractor and look in the hole where it came out you will see the ring gear. The gear on the end of your starter engages this. You can bypass your wiring by taking a screwdriver and shorting across the terminal on your starter that the battery cable hooks to and one of the other terminals. If your starter turns the motor over, then its your switch/wiring and/or ground cable thats either bad or not making a connection do to dirt, paint, corrosion, etc. Make sure you tractor is out of gear when you try this.
Post A Followup
: Re: Re: Re: Re: Farmall won't start
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
