856 int pto fixed
Posted by p miley on September 09, 2003 at 20:39:00 from (64.12.97.13):
thank you travis and aaces for your help i took the linkage off and backed off the controll valve and the pin was not broken so i started the tractor and held a wrench under the threded cap and pulled on the top of the controll valve and the pto worked what a good feeling i adjusted the linkage and every thing works fine thank you.
Post A Followup
: Re: 856 int pto fixed
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
