Re: Re: Re: Over charging Generator
Posted by Bob M on October 24, 2003 at 12:57:25 from (165.170.128.66):
In Reply to: Re: Re: Over charging Generator posted by Shaggy on October 24, 2003 at 12:08:00:
The stock generator shouldn't charge more than about 15 amp at WOT. More than that makes the generator run hot and can burn it out - will also boil your battery dry over time. A new regulator shouldn't need to be adjusted. Also without the right instruments and tools a regulator is nearly impossible for the average mechanic to get it set right. I suggest this instead: 1 - Check to see make sure there's not a ground in the wiring between the generator F and regulator FLD terminals: Pull the wire off the FLD terminal at the regulator with the motor running at half throttle. If the wiring is good the ammeter should drop to 0 or show a slight discharge with the wire disconnected. 2 - If your generator has an adjustable 3rd brush (the last ones made did not) you can adjust it to lower the current output: Loosen the 3rd brush clamp screw a couple turns - it's on the back end of the generator near the oiler cup. Then carefully rotate the 3rd brush AWAY from it's neighbor. The farther the 3rd brush is from the fixed brush, the lower the generator's output. Finally retighten the clamp screw. If these don't work, you probably have the wrong regulator - only cure is to swap it for the right one. Good luck!
Home
| Forums
Today's Featured Article -
Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
