Re: Re: Re: 300 U Runs Hot
Posted by Charlie on October 28, 2003 at 13:56:04 from (209.130.221.120):
In Reply to: Re: Re: 300 U Runs Hot posted by H2O_Control_Guy on October 28, 2003 at 13:42:12:
Your tractor is definitely hurting if you can only pull those plows in 1st gear. I have a 300U that I pulled 2-14 trailer plows with and didn't hardly warm the tractor up. I would look at a couple of things before tearing the tractor apart. On the oil presure what kind of oil are you using. I don't know if the multweight oils will do what you describe. Worn bearings will cause low oil pressure when they warm up. I would check the engine compression. I don't know what it should be but I'm thinking a good cylinder should be over 100 psi. If the compression is good maybe the tractor needs a valve job. Does the tractor smoke when its running - smoking could be worn rings which should also mean lower compression. Is the tractor tuned up OK. Mine loses power when the points are bad. Running a little hotter spark plug helps with todays gas. If you start checking some things and ruling them out maybe we can give you some more ideas.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
