Re: Re: Re: 350D Starter/Solenoid Connection Heati
Posted by Allan on October 30, 2003 at 08:22:21 from (148.63.132.164):
In Reply to: Re: Re: 350D Starter/Solenoid Connection Heating u posted by Doug G on October 30, 2003 at 07:34:22:
Doug,
Let me clearify here just a minute..
If that leg coming up out of the starter was cherry red....it is going straight to ground somewhere.
Make sure it is not touching the case of the starter...there should be an insulating grommet between it and the case.
Usually, the fields fail because of long periods of overcranking. That's why they tell you if the thing has not started within 30 seconds, to stop cranking and let it cool for a time.
Hope you get it figured out,
Allan
Post A Followup
: Re: Re: Re: Re: 350D Starter/Solenoid Connection Heati
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
