Re: IH 454 gas. broken gear shift arm. HELP!
Posted by Bernard le mécano on November 02, 2003 at 13:52:53 from (66.110.142.3):
In Reply to: IH 454 gas. broken gear shift arm. HELP! posted by Hurley Hughes on October 29, 2003 at 17:35:48:
Hi Hughes, you can chance this part by removal of the muti-control valve. It's on the left side of your tractor, under the hydrolic filter. Drain all the oil, remove pipe and PTO linkages,all the 3/8 bolts around the cover. With a short 7/8 open wrenche , you can remove the nut securing the gear shift lever. Put a new gasket and O ring when replace the valve
Bernard le mécano Québec Canada
Post A Followup
: Re: Re: IH 454 gas. broken gear shift arm. HELP!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
