Re: Re: Re: can a pto be added to an international
Posted by dick on November 03, 2003 at 08:41:30 from (67.31.129.191):
In Reply to: Re: Re: can a pto be added to an international 350 posted by tim adler on November 01, 2003 at 19:48:32:
Adding a PTO to the 300U or 350U has been a pretty frequent topic which I don't think has a proven anwer yet. The best guess(es) so far:
If it has a TA, it "probably" is set up for PTO, and which variety can "probably" be determined by the suffix on the serial number - "S" indicates gearing for IPTO, "R" indicates gearing for a transmission-driven PTO.
A "P" suffix is supposed to indicate IPTO gearing for tractors without a TA.
About the only way you're going to know for sure is to drain the transmission, take the cover plate off, and see if the gearing is actually present. Assuming it is, I "think" you can determine which variety you have by checking with the engine off: if the gearing turns freely with the clutch depressed, but doesn't when the pedal is out, it's transmission-driven; if it never turns freely regardless of the clutch position, it's geared for IPTO.
Good luck, and please post what you find out - this is still a vague area.
Post A Followup
: Re: Re: Re: Re: can a pto be added to an international
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
