Re: Re: Re: Removing bearing from axle with retain
Posted by greensboro george on December 22, 2003 at 07:37:16 from (167.102.133.160):
In Reply to: Re: Re: Removing bearing from axle with retainer o posted by Larry Kastens on December 21, 2003 at 19:39:11:
Larry,I just did this. I had to use a hammer and a block of wood to beat on the axle to push it out. If you beat directly on the end of the axle with a hammer, you can mess up the threads inside it. I had the bearing pressed off at a local garage, replaced the seal and retainer and had the bearing pressed back onto the axle. You will probably need a new pot metal retainer. Not available from IH. Maybe salvage yard. When you replace the axle you can hold the bull pinion and that small beveled washer in place with a large dowel. or better yet, get someone to hold it up for you. Watch your fingers. The sharp edges are like a guillotine in there. Good luck. Hope this helps.
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
