Re: 656 Hydro will not more forward or reverse.
Posted by Gary on January 01, 2004 at 06:18:55 from (66.226.101.74):
In Reply to: 656 Hydro will not more forward or reverse. posted by Mark on December 31, 2003 at 17:36:23:
Firt thing you are reversed on the charge and servo test ports. Servo test port is under the plate and charge pressure is on the multi valve but the pressures are fine. You said you took the check valves out. If you are talking about the ones inside the center section they don't cause much trouble and they will only keep it from moving in one direction depends on if is the forward or reverse check valve. Remove the two lines coming out of the side of the hydro housing. Put caps on the two fittings don't worry about capping the lines and try to move the tractor becareful the tractor will not stop when you push the pedal you have to stop it with the lever. If it moves the problem is in the drive control valve or foot-inch valve. If it doesn't move the trouble is inside the hydro. Possible relief valve stuck open.Either valve will keep it from moving. Email me if you want more detailed info
Post A Followup
: Re: Re: 656 Hydro will not more forward or reverse.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
