560 wide front mounting holes
Posted by Colorado Curt on January 02, 2004 at 07:44:12 from (146.174.51.103):
Yesterday I tried to put a wide front on my 560 and everything was going too smoothly. The narrow front came off with no problems, the wide front (from a 544) rolled into place and everything lined up perfectly. It was too good to be true. When I started tightening the 4 front bolts, it felt like the bolts were bottoming out. I checked the hole depth and there is plenty of room for the bolt. Is it possible that the holes are not tapped completely?
Post A Followup
: Re: 560 wide front mounting holes
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
