Re: 560 tractor and engine serial number
Posted by Hugh MacKay on January 18, 2004 at 05:36:17 from (209.226.247.121):
In Reply to: 560 tractor and engine serial number posted by jrex on January 18, 2004 at 04:19:21:
jrex: The 560 tractor serial number is located on the left side of the clutch housing. The engine serial number will be on the engine itself, I don't remember exactly where. Just under number one plug or injector was the common place for engine serial numbers on the older IH tractors. It was always a raised, machined, smooth surface about 1/2" high and 1.5" long with numbers stamped in the cast. I can't remember when or if that changed.
If your thinking these numbers are the same or even close, it's not likely. Both the gas and diesel engines used in the 560 had many other applications, such as combines, dozers, stationary engines, other tractors, etc., so unless it is a very early 560 the engine serial number may be much larger than tractor serial number. If trying to determine if it is the original engine your best way would compare casting codes on engine with castings on the rest of tractor.
Post A Followup
: Re: Re: 560 tractor and engine serial number
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
