Re: Dead 574
Posted by parts man on January 22, 2004 at 21:04:10 from (142.166.242.194):
In Reply to: Dead 574 posted by Matt H. on January 22, 2004 at 11:48:56:
I'd double check that float heighth, and make sure that the plug wires are on correctly.
I think the firing order should be 1-3-4-2.
To find #1 on the distributer take out #1 plug, put you finger in the hole, and slowly turn engine till you feel compression. Bring it to TDC and where the rotor points is #1. crank the engine and watch the rotor, the direction it turns is the direction you put the wires on in order 1-3-4-2.
HTH
Post A Followup
: Re: Re: Dead 574
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
