Re: Re: Supporting SA lift arm from axle casting?
Posted by Darren in TN on January 30, 2004 at 08:42:38 from (128.158.130.56):
In Reply to: Re: Supporting SA lift arm from axle casting? posted by Hugh MacKay on January 30, 2004 at 08:23:55:
Hugh,
You're crystal clear. If I can get these pins threaded and installed where I want them, they'll be just at 29" wide (if I'm remembering my measurements correctly.) I had looked at the cultivator mounts for my SA and discounted the idea, but now that you mention it that might be a lot easier than trying to cut new threads on those heavy pins... I think I remember seeing Cat. III to Cat. I conversion pins that had a diameter of 1-1/4" shank down to a 7/8" Cat. I pin... I'll have to go revisit that idea. Thanks for the info and for the idea!
Darren
Post A Followup
: Re: Re: Re: Supporting SA lift arm from axle casting?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
