Re: Re: Re: Re: Hydraulic strength?
Posted by Mark on February 02, 2004 at 10:24:50 from (199.46.199.230):
In Reply to: Re: Re: Re: Hydraulic strength? posted by Jim on January 31, 2004 at 10:16:52:
Get a high pressue gauge (Northern Tool has a 0-5000# for $10). Put it in your high pressure line and measure the pressure with the tractor at PTO speed. Put the hydraulics back like they were. Measure the internal diameter of your cylinder (piston width across the top) and divide by 2. Take this number x the same number x 3.14. Multiply this by the pressure you measured and you have your lift capacity at the cylinder. Any lift arm length will either add to this or subtract depending on whether or not you have distance between the cylinder and what you want to lift. So for a 1200 lb measurement of pressure, and a 3" cylinder we have 3"/2 = 1.5" x 1.5" x 3.14 x 1200 psig = 8482 lbs lifting capacity according to my calculator. If the lift arm pivots at the tractor and the cylinder is 1 ft from the tractor and the length of the arm (at the point where you are lifting) is 3' from the tractor then you have a second class (as I recall) lever gain of 3' - 1 ' = 2 ft so lbs x ft = 8482 x 2 (feet x pounds....ft-lbs)or 16,964 lbs lifting capability. Now with that said, the practical side of all this is hydraulic leaks, piston blow-by and ability of your tractor to support that kind of load. Probably a couple of thousand pounds is more practical. Awesome isn't it, what hydraulics do for us every day in every walk of life. Mark
Home
| Forums
Today's Featured Article -
Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
