1066 won't start
Posted by Dan on February 21, 2004 at 19:05:30 from (205.188.209.82):
Put a cam and main bearings in our 1066. Got it back together today and can't get it to fire without ether. Cracked the injector lines and getting diesel to all injectors.
Injector pump gear got unmeshed with the idler when we pulled the front cover off. So I am suspecting I am out of time. However, when I put the engine at 18 on the flywheel to check the timing of the pump, the pointer and mark are almost right on. Off by less than the width of the pointer. Since the pointer on the flywheel has a slight bit of play to it, you can get the pointer and mark on the pump, to match up with the pointer and 18 on the flywheel.
How exact is the timing? Is that the culprit, or do you guys have any other ideas? Thanks.
By the way, as was pointed out earlier, I am not an IH mechanic, but would gladly take the advice of one, shade tree or otherwise.
Post A Followup
: Re: 1066 won't start
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
