Re: IH 6 cyl oil pressure
Posted by Aces on February 29, 2004 at 11:56:08 from (207.223.245.15):
In Reply to: IH 6 cyl oil pressure posted by ChadS on February 28, 2004 at 19:13:39:
The 460 560 some of the 706 and I think some first 656 had a cast iron filter base and yes the relief valve is in the base. Never had oil pressure trouble with the cast iron base. Then IH came with the through away filter and an aluminum filter base and we had big troubles with the aluminum bases, just had a wafer valve in it. So if you have the aluminum base with the through away filter, take the base off and take the valve out to see how the valve and the seat looks could be the problem.
Post A Followup
: Re: Re: IH 6 cyl oil pressure
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
